Vaatwasser.nl / Forum / Reviews vaatwasser producten en winkels / MMOEXP POE is the core of the endgame
Reactie toevoegen
Adrianayng
Once you’ve completed the ten acts of Path of exile currency campaign, the true game begins: the endgame Atlas system, built around running maps. Mapping is the core of the endgame and the primary way players earn experience, currency, and powerful loot. However, mapping can be overwhelming for new players, especially with the numerous mechanics, Atlas progression systems, and loot modifiers. This guide will walk you through the fundamentals of efficient mapping and how to maximize both your profits and your enjoyment.
What Are Maps?
Maps in Path of Exile are items that open portals to randomized dungeons, each with its own layout, monster density, boss, and modifiers. They come in varying tiers, ranging from Tier 1 (low-level) to Tier 16 (high-level), and are part of a larger system called the Atlas of Worlds. Each map corresponds to a unique location on the Atlas, and completing maps unlocks progression bonuses and influences future drops.
Reroll Bad Mods:
Some map modifiers can be extremely dangerous depending on your build. For example, if you rely on life recovery, “No Life Regen” could be a death sentence. Use Orbs of Scouring and Orbs of Alchemy to reroll maps as needed.
Use Scarabs and Fragments:
Scarabs: These are used in the map device to add mechanics like Breach, Abyss, or Legion for additional loot and encounters.
Fragments: Offer additional quantity and bonuses. Common examples include Sacrifice Fragments (from Atziri runs) or Shaper/Elder fragments.
The more investment you put into a map, the greater the potential reward—but also the greater the risk.
You earn Atlas points by completing maps and defeating bosses. Be strategic—if you want currency, specialize in mechanics like Expedition, Harvest, or strongboxes.
Map Sustain Tip: Use the “Favoriting” system to increase the drop rate of specific maps. Choose layouts you enjoy or that contain valuable divination cards.
Speed vs Profit: Finding Your Balance
Efficient mapping is about balancing speed and profit. Depending on your build, you might want to clear maps quickly with minimal investment (“alch and go”), or you may want to fully invest in maps for maximum loot (“juicing”).
Alch and Go: Use an Orb of Alchemy on a map and run it. Fast, cheap, and decent returns.
Juicing Maps: Add Scarabs, Sextants, Delirium Orbs, and use Atlas passives for maximum loot. Slower but much higher returns.
Start with low investment strategies and move to juiced mapping once your character and currency reserves can handle it.
Loot Filtering and Inventory Management
With the sheer volume of loot dropped in maps, a good loot filter is essential. It highlights valuable items and hides junk, helping you save time and inventory space. Use popular filters like NeverSink’s Filter, which can be customized based on your progression.
Also, use dump tabs and sorting systems in your stash to quickly offload items between runs. This keeps your inventory clear and maintains momentum.
Know When to Skip or Engage
Not every mechanic is worth your time. While mapping, make smart decisions:
Skip Dangerous Mods: If your build can’t handle reflect, avoid it.
Skip Time-Wasters: If you’re optimizing for profit per hour, skip mechanics that offer low returns or slow you down, unless you're targeting specific loot.
If you’re targeting unique items, divination cards, or league-specific rewards, then plan your strategy accordingly.
Final Thoughts
Efficient mapping in Path of Exile is the backbone of endgame progression and currency generation. Whether you're casually running T10s or fully juicing T16s with multiple mechanics, there's a mapping style for every player. Master the basics—map preparation, Atlas strategies, and loot management—and you’ll find yourself growing stronger, richer, and more capable with every run.
In Wraeclast, the map is your battlefield. Learn it well, and you’ll never run out of paths to buy POE divine orbs.
Reactie toevoegen
