Vaatwasser.nl
	 / 		Forum
	 / 		Inbouwen en aansluiten van vaatwassers
	 / 		U4GM Diablo 4 How to Build a Durable Rup
 |     							U4GM Diablo 4 How to Build a Durable Rup |
jean
						  jean
Hardcore players need a version of the Rupture Barbarian that can survive chaos while maintaining powerful offense. The goal is durability without sacrificing the skill’s identity as a bleed-based execution build.
Start with Defensive skills like Iron Skin, Rallying Cry, and Challenging Shout. These abilities create a strong defensive foundation, granting barrier, fortify, and damage mitigation that ensure survival during high-risk encounters.
For your offensive core, stick to Flay and Rend for consistent bleeds. Rupture then becomes your finisher rather than your primary attack. This playstyle minimizes exposure time and allows quick, controlled strikes.
Stat prioritization is crucial—stack Strength, Maximum Life, and Damage Reduction from bleeding enemies. You’ll deal consistent damage while gaining passive protection from your primary mechanic.
In gear and Aspects, the Aspect of Numbing Wrath is invaluable for damage reduction, while the Iron Blood Aspect grants fortify when attacking bleeding enemies, ensuring constant defense uptime.
Paragon boards should lean toward defensive nodes such as Armor and Damage Reduction under Berserking. While offense remains important, surviving one-hit kills takes precedence.
In Hardcore mode, pacing is vital. Avoid overcommitting to large groups—let your bleeds do the work. Rupture only when enemies are near death, reducing risk from retaliation.
The durable Rupture Barbarian thrives through patience and planning, turning the battlefield into a slow but steady execution ground. Every move counts, and every Rupture is deliberate.
Your shortcut to power starts at https://www.u4gm.com/d4-items
